Upload multiples files
Re: uplod multiples files
Yes. How do you specify those multiple files? Do you have a fixed list of files you want to upload? Or do you want to upload all files in some folder? Or all files that match some wildcard/mask or other criteria?
Angel-ito
Madrid-Spain
upload to files
We are developing a backup application that uploads to the server those files that have been changed, being able to upload all the files in a directory, some or none.
That is why what we thought was to generate a list of files and path to upload and upload them with just one session to save time.
Are there or do they have any routine that can do this other than a file-to-file control?
Thank you
Reply with quote E-mail
Angel-ito
Madrid-Spain
Thank you very much for all the answers.
One last question, how can I tell the synchronizationResult.Check() statement to ignore the errors? It turns out that when it finds an open file, it gives an error and stops uploading even if we control the error with a try catch block
Thank you so much for everything
Angel-ito
Madrid-Spain
Thank you for all the answers and sorry for the delay in thanking.
And finally I would like to know if you can synchronize file by file, unfortunately I have to do the project file by file and not directory by directory.
Angel-ito wrote:
Is it possible to keep multiple file versions in directory sync?
I do not know what you mean. What "versions"? Please elaborate.
Is it possible to sync a directory and not internal directories to sync?
In other words, synchronization is not recursive
See https://winscp.net/eng/docs/faq_script_non_recursive
How can I make a mask so that it saves the files from a certain date and that it does not go through the subdirectories.
See https://winscp.net/eng/docs/file_mask#size_time
Angel-ito
Madrid-Spain
I mean the following:
A file is modified on Monday, Tuesday and Wednesday. I would like to know how it can be done to have the three versions in the remote directory.
We will be able to implement a differential or incremental copy system.
Thank you
Angel-ito
Madrid-Spain
And one last question,
How can I make "FileMask" contain a non-recursive option and make the date greater than or equal to a given date.
Thank you
Angel-ito
Madrid-Spain
re: Uplod multiple files
Hello, when I use the PutFiles function (to record a directory using the mask property "*. *;> 2020-05-01 | * /" I always get the same error, I attach my code
Error transferring file 'C: \\ projects \\ test.txt.txt'. \ R \ nCopying files to remote side failed. \ R \ nFilename invalid"}
string LocalDirectory = currentDir + @ "\ *";
TransferOperationResult transferResult;
transferResult = session.PutFiles (LocalDirectory, RemoteName, false, transferOptions);
You can append a timestamp to the destination filename.
Sorry that's too broad/vague. We do not know anything about format/structure of your files.
Re: re: Uplod multiple files
Angel-ito
Madrid-Spain
uplod multiple files
Hello again
Is it possible to get the list of files to be synchronized in a directory before uploading them?
Thank you very much
Angel-ito
Madrid-Spain
Hello there,
Is it possible to retrieve the hash of a file that is on the server?
In other words, I would like to check the hash of the file on the server with the file to be copied and if the hashes are different then replace the file on the server.
Thank you
Angel-ito
Madrid-Spain
Re: uplod multiple files
Could you send us an example of this functionality in C#?
Thank you very much and as always, sorry for the inconvenience
Sorry, but this is not a code writing service. What did you try? Did you face any specific problem?
