running ps script that uses winscp.dll asembly
olga
I am trying to automate an sftp connection using ps script. When i run the ps script under my user - it runs ok, when i run under service user the script fails at session.open command.
In the script i have specified the username and password for user to connect to sftp, but i thing when the script runs under service user configuration is looking in user profile for .rnd file.
How could i run the script using a user that does not have this file?
  • ps.txt (2.15 KB, Private file)
Re: running ps script that uses winscp.dll asembly
How does it "fail"? What error do you get?
Please post session log file (Session.SessionLogPath) from both machines.
When i run the windows task under my user it creates the session log (attached). When i run under service username it does not create any session log file. Is there any configuration parameters i have to add into the script? I have read about .ini file - but i am not sure how to use it
