ERROR 24
mozerd
Customer
Nepean ON Canada
ERROR 24
Just purchased WinSCP from the Microsoft Store. After logging into my Router and attempting to view my files in a USB drive the following error pops up::
Error
Copying files from remote side failed.
The specified file was a directory in a context where a directory cannot be used.
Error code: 24
Error message from server: Is a directory
OK Help
Version of WinSCP is 5.15.9 running under Windows 10 1909 [OS Build 18363-535]
I am attaching a graphic showing the file structure in my Router under WinSCP
disk1 and disk2 shown in the graphic are usb memory sticks attached to the router
Any idea how to fix this please?
Re: ERROR 24
Thanks for your post.
What exactly are you doing when "attempting to view my files"?
mozerd
Customer
Nepean ON Canada
Log file for error 24
I was using WinSCP to view some files that reside on my Router storage called disk2. My action was double click disk2 to view the files. Normally the files would just appear there automatically but for some reason WinSCP does not display the contents of the storage disks.
Attached is log file requested.
I am also attaching a graphic showing how the Files display using my Router's Files Tool:
Description: LOG File
