Recover columns from queue panel
ecerichter
Brasil
Hi!
I've hidden the progress and speed columns from queue, and cannot find where to check them back.
Would you provide kind guidance?
Thanks in advance,
Edson
Re: Recover columns from queue panel
There's no way to hide the columns. Maybe you have resized them to a zero width. Place your mouse cursor just behind the column separator line on place of the invisible column. The cursor should change. Then drag to the right to reveal the column.
thochstein
Same problem
I have the same problem. The horizontal scroll bar is huge, and I only see strange artifacts in the column headings bar to the right of the Destination. If I could find the separator line, I could double-click it, but I think there's something fundamentally broken.
Re: Same problem
@thochstein: Thanks for your report.
