The system cannot find the file specified.
Ritter
Russia
Found one funny bug. When I try to open folder or file which have "я" ("ya") cyrillic character in name winscp shows "The system cannot find the file specified" error. BUT if I try to open folder or file which have "Я" ("YA") cyrillic character in name it opens perfectly.
Re: The system cannot find the file specified.
Ritter
I tried to open FTPS using filezilla but got the same error.
But if I just open FTP (without SSL) through Windows Explorer, then this problem does not occur.
This can be the problem:
> 2020-01-03 13:43:02.332 PASS **************
< 2020-01-03 13:43:02.334 530 User cannot log in.
. 2020-01-03 13:43:02.345 Login data contains non-ascii characters and server might not be UTF-8 aware. Trying local charset.
Can you try to change your password to plain ascii?
