Failure with error code 4 when moving remote files from path A to B, can't overwrite
jmar83
Failure with error code 4 when moving remote files from path A to B, can't overwrite them if there are some files with same name (maybe same content) on the target directory.
Why??!
In my opinion, this is NOT an error... WinSCP should ask me something like "There is alreay a file X on path ABC. Do you want to overwrite it with the new one?"
Screenshot here:
https://i.ibb.co/D4SWWCY/Unbenannt.png
Thx for feedback,
Jan
Re: Failure with error code 4 when moving remote files from path A to B, can't overwrite
Can you overwrite the file using any other SFTP client?
jmar83
it's not a chown or chmod-problem, i can also overwrite files with winscp... but not when i move them from remote to remote location.
i can send you the log if you give me your mail address. log is not for public.
_________________
With best regards
jmar83
You can find my email address in my forum profile. But you can also attach the log here and mark is as private (as mentioned in my post above).
