Automatic Sync Interval or Schedule
ijaz_ali
Dear Team,
Your software is very good and syncing perfectly but user has to sync manually every time. I would like to request you if you can add another feature of automatic synchronization after a short interval or user can make an automatic synchronization schedules where a user do not need to sync manually. for example Windows Server Backup automatic Backup schedules.
Regards,
Ijaz Ali
ijazali@cmitfod.com
Re: Automatic Sync Interval or Schedule
Do I understand right, that you do not need any more assistance?
Yes. You may close this topic. Thanks.
Re: What does Delete files do in "Keep remote directory up to date" feature.
ijaz_ali wrote:
What would be the impact of Delete files option if I use Keep remote directory up to date.
Shall it delete files after sync from original or local directory?
It will synchronize the deletes. So if you delete a local file, WinSCP will delete a matching remote file.
ijaz_ali
Thanks dear for the update.
