Get & Put with WinSCP
CarterJohn11
USA
Hey All,
I'd like to move files from C:\Jobs\AF_SYNC\ and put them in a remote FTP folder. Once uploaded I'd like to delete the file from the C:\Jobs\AF_SYNC\.
In addition I'd like to automate a get or sync between a remote FTP folder and a local C:\Jobs\AF_INPUT\ directory. Is there a way to script this out in WinSCP then save as a batch file that I can schedule?
Some of these files will be pretty large so if possible some checks to make sure it uploaded correctly would be great.
Thank you for any assistance if someone has already done this.
Re: Get & Put with WinSCP
Just do
put -delete "C:\Jobs\AF_SYNC\*" "/remote/path/"
WinSCP can generate a script template:
https://winscp.net/eng/docs/guide_automation#generating
See also:
