Saving multiple sites into List
Goodson12
What I would like to be able to do it send out a specific file to a number of different sites with the click of a button. What would need to happen, I think, is that it winSCP would connect to one site load the file then close that connection and then open the next site, and so on. I would also like it to put that file in a specific location on that site. Is this possible? If not are there any good programs that do allow you to do this?
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
open xxxx:xxxxx@192.168.0.23
close
# Exit WinSCP
I get the response EAccess Violation
what does that mean?
It is a bug. If you are using 3.8, please downgrade to 3.7.6/
