Files being skipped during upload
I'm having issues where some files are being skipped in an upload to an FTP server. I've attached the script and log file and I'd be very grateful if anyone can give me a clue as to why the files are being skipped. Once skipped, it seems that they are deleted as they never get selected in a subsequent upload.
I am uploading XML and PDF files in two separate uploads from the same folder to a separate folder for each on the ftp site (I hope that makes sense). Could that be the issue? Would I be better off putting the XML and PDF files in separate folders for upload to the ftp site?
I'm using WinSCP v5.15.9 running on an Azure server Windows Server 2016 Datacenter.
I'd be grateful for any pointers on this.
Thanks,
Gary.
garyn
Sydney, Aus
Yes, 1097_1.pdf was one of them. I can see it was skipped during the xml upload due to the filter. However, as it was not picked up during the pdf upload, I'm wondering if it's a timing thing and whether that particular file was dropped into the folder after the pdf upload command had finished and then WinSCP deleted it once the whole batch had finished. Is that possible?
That's possible.
But this is not possible. The put -delete deletes only the files that are successfully uploaded. And the deleting happens as part of the put command, not "once the whole batch had finished".
garyn
Sydney, Aus
Thanks. It's a bit odd. Do you have any ideas what might possibly cause files to disappear from the folder without being uploaded?
I'm wondering whether to put the pdf and xml files in separate folders and run two separate scripts - do you think that might help, or at least be a better way to do it?
Gary.
No. But I'm sending you a development version of WinSCP, which logs the deletion of the local source files. Try to use it and post a log file once any file disappears again.
I do not thing it is a better way and I do not thing it would make any difference.
garyn
Sydney, Aus
Thanks. I’ll give that a go when I’m back in the office in the new year and let you know how it goes.
Gary.
