Error where download the file from ftp
borkhalenko
Kyiv
Hello. I have a script do download files from ftp:
set mydate=%date:~0,2%_%date:~3,2%_%date:~6,4%
winscp.exe /script="C:\Program Files (x86)\winscp_download_checks\download_settings.txt" /log="D:\MhpAutomatiz\winscp\LOG\%mydate%.log"
download_settings.txt:
option batch abort
open ftp://LOGIN:password@site -timeout=10
get -preservetime -nopermissions -filemask="*.zip" -transfer=automatic *.zip D:\MHPAutomatiz\Download\
Log (part 1):
. 2019-12-03 18:20:00.746 File: '/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip' [2019-12-03T16:18:04.000Z] [1714]
. 2019-12-03 18:20:00.746 Copying "/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip" to local directory started.
. 2019-12-03 18:20:00.746 Binary transfer mode selected.
. 2019-12-03 18:20:00.746 Starting download of /DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip
> 2019-12-03 18:20:00.746 TYPE I
< 2019-12-03 18:20:00.746 200 Type set to I
> 2019-12-03 18:20:00.746 PASV
< 2019-12-03 18:20:00.746 227 Entering Passive Mode (176,111,58,234,214,254)
> 2019-12-03 18:20:00.746 RETR DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip
. 2019-12-03 18:20:00.746 Connecting to 176.111.58.234:55038 ...
< 2019-12-03 18:20:00.746 200 TYPE is now ASCII
< 2019-12-03 18:20:00.761 227 Entering Passive Mode (91,234,35,10,246,180)
> 2019-12-03 18:20:00.761 MLSD
. 2019-12-03 18:20:00.761 Connecting to 91.234.35.10:63156 ...
< 2019-12-03 18:20:00.777 150 Accepted data connection
. 2019-12-03 18:20:00.777 Data connection closed
< 2019-12-03 18:20:00.777 226-Options: -a -l
< 2019-12-03 18:20:00.777 226 4 matches total
Log (part 2):
< 2019-12-03 18:20:01.058 150 Opening data channel for file download from server of "/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip"
< 2019-12-03 18:20:01.058 226 Successfully transferred "/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip"
. 2019-12-03 18:20:01.058 Data connection closed
. 2019-12-03 18:20:01.058 Download successful
. 2019-12-03 18:20:01.058 Transfer done: '/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip' [1714]
. 2019-12-03 18:20:01.058 Deleting file "/DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip".
> 2019-12-03 18:20:01.058 DELE /DOC_D11133_F10_P76_U303_2019-12-03_18-17-56.tcudoc.zip
And I have a file with 0 bytes on my PC. How can I find, where an error causes?
Thank you!
Re: Error where download the file from ftp
I do not understand your two-part log file. Isn't the second part actually a part of the first part? Can you post a full log file? Though if WinSCP logged that it downloaded 1714 bytes, the file should not be empty.
