Running file command using non-default shell?
OrionRed
Ohio
I have WinSCP set up to use SCP on a secure server. I have configured it to do a "sudo su - userid" to open the file listings and to do the transfers. However, when i run a command, it seems to revert back to my "normal" user id to run the command.
Is there a way to have it use the same shell that it used to start the session?
Re: Running file command using non-default shell?
How exactly did you "configure" it?
Did you follow the documentation? https://winscp.net/eng/docs/faq_su
