Delete files first before transferring new files
Ch33s3
World
Hi everyone,
I'm using a scripted batch automation to sync files from a local storage to a FTP location - it works like a charm since months! Thank you very much for your great tool and this great forum!
My Question would be if it is possible for WinSCP to first check remote files against local storage assets and delete obsolete remote files FIRST before transferring new files to the remote location?
This is my current setup, maybe you guys could help me out? ;
%winscp% /command ^
    "option batch on" ^
    "option confirm on" ^
    "open %FTPTARGET%" ^
    "synchronize remote -delete -mirror %destWF% %destDF%" ^
    "exit" ^
    /log=%destDL%\Sync_%datestamp%.log ^
    /loglevel=-1
Cheers, have a nice day! :)
Re: Delete files first before transferring new files
No, there's no such option in scripting.
It is not that difficult to implement this e.g. in PowerShell with help of .NET assembly Session.CompareDirectories method.
https://winscp.net/eng/docs/library_session_comparedirectories
It will be even easier, once this is implemented:
Issue 1802 – .NET assembly functionality to process individual ComparisonDifference instances
Ch33s3
Thanks for the fast reply Martin!
Alrighty then, maybe I'll just call some PowerShell instance how you've described it.
Cheers, have a good day!
Ch33s3
World
I finally took some time and assembled some code to work in PowerShell with .NET assembly the usual sync task already works and is very fast, thanks!
Currently the compare files section still doesn't work. In PowerShell ISE it's telling me that
"[WinSCP.ComparisonDifference] no Method with name "Check" contained.
Maybe someone is able to find the error (session options are stored seperatelly and work with sync)
# Compare Files
$comparisonDifferenceCollection = $session.CompareDirectories(
    [WinSCP.SynchronizationMode]::Remote, "C:\Users\XXX\Desktop\WATCHFOLDER", "/DESTINATION", $True ,$False)
# Synchronize files #<---WORKING ALREADY!
# $synchronizationResult = $session.SynchronizeDirectories(
#     [WinSCP.SynchronizationMode]::Remote, "C:\Users\Christoph\Desktop\WATCHFOLDER", "/DESTINATION", $True ,$True)
Greetings, have a great weekend!
I do not think you can get that error in the code you have posted – There's no Check call. The error must be from some other part of your code.
Ch33s3
World
Thanks! It seems that:
# Throw on any error
#$synchronizationResult.Check()
Caused the error before, sorry I'm new to PowerShell. But I like it already, like an "unlocked" version of WinSCP :)
Now it seems to spool through that part without any error so far.
I think I'm close, I just have to tell the script that it should check with local and if FileX is not present there, delete FileX on remote location..., (then proceed to the sync routine)
The return value ComparisonDifferenceCollection should probably be utilized somehow I assume?
Edit: here is my "frankensteined" build so far: https://pastebin.com/D9HtwWhJ
Cheers!
$localPath = "C:\Users\XXXX\Desktop\WATCHFOLDER"
$remotePath = "/DESTINATION"
$diffs = $session.CompareDirectories(
    [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $True)
foreach ($diff in $diffs)
    if ($diff.Action -eq [WinSCP.SynchronizationAction]::DeleteRemote)
        Write-Host "Deleting $($diff.Remote.FileName)..."
        $session.RemoveFiles(
            [WinSCP.RemotePath]::EscapeFileMask($diff.Remote.FileName)).Check()
    if (($diff.Action -eq [WinSCP.SynchronizationAction]::UploadNew) -or
        ($diff.Action -eq [WinSCP.SynchronizationAction]::UploadUpdate))
        Write-Host "Uploading $($diff.Local.FileName)..."
        $session.PutFiles(
            $diff.Local.FileName, $remotePath + "/*", $False).Check()
Ch33s3
Aaah, thats it!
For testing, I just quickly merged the deleting part and it works like a charm!
Cheers, have a good day and thanks for all your help !!!
With WinSCP 5.16.5 ComparisonDifference.Resolve, the code can be simplified to:
        $diff.Resolve($session) | Out-Null
