To allow both windows to be remote or both local
s4ws
Currently you only can have PC at the left and Unix/Linux at the right panel in WinSCP.
Request is to allow both panels to be Unix/Linux. Or, possibly, both panels to be Windows but the existing app called Total Commander is the king in this area for decades and possibly is difficult to overcome. Basically this request will make WinSCP a tool resembling Total Commander but for handling Unix/Linux via PC. Unix/Linux people without such graphics users interface still work like Neanderthals.
Re: To allow both windows to be remote or both local
How do I achieve two local panels? Didn't find the option and didn't find any new feature listed in the changelog
ueberbrot
Thank you for the information. Based on your previous comment I thought it would be already a feature.
If you register here, we can send you a development version for testing soon.
update
Was this feature included in the latest update?
Was wondering if we could open up two local views as well to just transfer things folder to folder easier.
Re: Was this feature included in the latest update?
Sorry can ignore this earlier msg, seen that it's coming in version 6.0 which is to be released soon :)
Btw, we are planning to support two local panels in the next release.
This is a great feature in the latest version. Is there a how-to guide about this to make sure I'm using it as intended?
