Session.SynchronizeDirectories error
mlogan
I am using the SynchronizeDirectories in PowerShell, through the .Net assembly to clear a remote directory. Sometimes, the SynchronizeDirectories function will try to delete a folder that is not empty.
I am using SynchronizeDirectories likes this:
$synchronizationResult = $session.SynchronizeDirectories(
                [WinSCP.SynchronizationMode]::Remote,
                "C:\LocalEmptyFolder",
                "/Remote/Folder/With/Content,
                $True,
                $True,
                [WinSCP.SynchronizationCriteria]::Either,
                $transferOptions)
    $transferOptions.PreserveTimestamp = $True
this will sometimes result in this error:
##[error]Exception calling "Check" with "0" argument(s): "Error deleting file
'/Remote/Folder/With/Content/Foler_1'.
The directory is not empty.
Error code: 18
Error message from server (en): The directory is not empty. "
I have noticed this only happens with a folder that has an underscore in the name. The error occurrs when calling $synchronizationResult.Check().
Re: Session.SynchronizeDirectories error
mlogan
Attaching the session log
We were able to replicate the error. I'm attaching a scrubbed log file.
  • winscp_scrubbed.log (23.31 KB, Private file)
mlogan
I did not capture that when the issue occurred. I will let you know when it happens again. The issue is not repeatable when it occurs. Re-running the script will run with success.
