Delete Files
franclim_mendes@...
Delete Files
I want do donwnload files from sftp address to and I have used getFiles function. One of the parameters is remove files on original location. The files are in a folder.
When I call this function, it also has deleted my folder.
I've tried move instruction and remove instruction too.
In every cases my original folder is deleted, s this normal?
Can anyone help me ?
Re: Delete Files
That depends on what your arguments to GetFiles are.
If you download the folder itself, the folder is also deleted:
session.GetFiles("/remote/path", ..., true)
If you download the files in the folder, the folder itself is not deleted:
session.GetFiles("/remote/path/*", ..., true)
