Ask to replace files
delbg
Hi all :)
I was wondering if there's a way to prompt for 'replace' in case a whole directory is being uploaded.
I currently only get a prompt if i should replace the whole directory, but i would like to have the option (when uploading a directory) to be prompted for each file.
Br
Re: Ask to replace files
You are probably using SCP protocol. This is due to a limitation of the protocol.
Use SFTP, if you want the confirmation for individual files.
