Lost connection. Timeout detected. (control connection)
sraptis
Greece
I am trying the .NET assembly under VB .NET.
While when using the application it self I can transfer files without error, when I use this simple code:
Dim sessionOptions As New SessionOptions
With sessionOptions
    .Protocol = Protocol.Ftp
    .HostName = HostName
    .PortNumber = Port
    .UserName = ftpUsername
    .Password = ftppassword
    .FtpMode = FtpMode.Passive
End With
Using session As New Session
    ' Connect
    session.Open(sessionOptions)
    ' Upload files
    Dim transferOptions As New TransferOptions
    transferOptions.TransferMode = TransferMode.Binary
    transferOptions.OverwriteMode = OverwriteMode.Overwrite
    Dim transferResult As TransferOperationResult
    transferResult = session.PutFiles(mFromFile, mToFile, False, transferOptions)
    transferResult.Check()
End Using
I am getting the error message:
Lost connection.
Could not retrieve file information
Can't get attributes of file ......
I want to add that the file has been transferred OK, but I get this message.
Any clues?
Stavros
Re: Lost connection. Timeout detected. (control connection)
sraptis
Greece
Thank you for your help.
One correction at my previous message.
The error was at the rename function not at the upload. My mistake
With sessionOptions
    .PortNumber = Port
    .Password = ftpPassword
    If ftpUsePassive Then
    Else
        .FtpMode = FtpMode.Active
    End If
End With
    ' Connect
    session.SessionLogPath = "scp_rename.txt"
    session.MoveFile(mFromFile, mToFile)
End Using
I am attaching the log file.
The error message that I am getting is:
Lost connection.
Can't get attributes of file 'FrVessel/tmprry-....
If you login with WinSCP GUI (or any other FTP client) on the same machine as you run your code, can you see a directory listing?
