Which files are not copied ?
frederic26
Hello Everybody,
How to know which files are not copied, when transfering a lots of files ?
best regards,
Frederic
frederic26
Re: Which files are not copied ?
Do you mean which files are excluded due to a file mask? Or why they would not be copied?
Yes, exactly: why some of the files would not have been copied. Like a log file or a summary of files that are copied, and errors (files not copied).
BR
Well, you didn't really clarify it. You wrote "yes exactly" on my answer about the file mask. Yet then you wrote that you want too see errors. When a file is excluded due to a file mask, it is not an error.
Anyway, if you want to see errors, check XML logging:
https://winscp.net/eng/docs/logging_xml
