Unable to connect/synchronize using SFTP
DDPSC
St. Louis MO
We are able to connect using the WinSCP client using the same login credentials etc as used in the code below, but we get no errors reported nor does the file get uploaded when running the code. We are successfully using the same code to connect to a different server with no problems. Any help is much appreciated.
 Try
            ' Set up session options
            Dim sessionOptions2 As New SessionOptions
            With sessionOptions2
                .Protocol = Protocol.sftp
                .HostName = "xxx.zzz.com"
                .UserName = "user"
                .Password = "password"
                .SshHostKeyFingerprint = "ssh-ed25519 256 xxxxxxxxxxxxxxxxxxx="
            End With
            sessionOptions2.AddRawSettings("FSProtocol", "2")
            Using session2 As New Session
                ' Connect
                session2.Open(sessionOptions2)
                ' Upload files
                Dim transferOptions2 As New TransferOptions
                transferOptions2.TransferMode = WinSCP.TransferMode.Binary
                Dim sDate2 As String = DateTime.Now.AddDays(1).ToString("yyyyMMdd", System.Globalization.CultureInfo.GetCultureInfo("en-US"))
                Dim transferResult2 As TransferOperationResult
                transferResult2 = session2.PutFiles("e:\inetpub\wwwroot\iLabs\Imports\" & sDate2 & "_pi_funds.csv", "incoming/", False, transferOptions2)
                ' Throw on any error
                transferResult2.Check()
                ' Print results
                For Each transfer In transferResult2.Transfers
                    Response.Write(transfer.ToString())
                Next
            End Using
        Catch er As Exception
            Console.WriteLine("Error: {0}", er)
        End Try
Thank you
Re: Unable to connect/synchronize using SFTP
