Winscp assembly getting timeout
kolotan
Hi folks,
I had set these setting
sessionOptions.Timeout = new TimeSpan(0,2, 0);
if (session.Opened == false) {
session.Open(sessionOptions);
session.Timeout = new TimeSpan(0, 3, 0);
but still i am hit with this timeout error.
System.NullReferenceException: Object reference not set to an instance of an object. at WinSCP.Session.CheckForTimeout(String additional) at WinSCP.Session.Open(SessionOptions sessionOptions)
from the winscp log below, it seem to get this timeout error after 60sec.
[2019-10-01 15:30:27.261Z] [0001] Session.SessionOptionsToUrlAndSwitches leaving
[2019-10-01 15:30:27.261Z] [0001] Command: [open "sftp://Oxxxxxxxx@xxxxxxxx:xx" -hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:x:xx:xx:xx:xx:xx:xx:xx" -privatekey="xxxxxxxxxxxxxxxxxx.ppk" -timeout=120]
[2019-10-01 15:30:27.261Z] [0001] ExeSessionProcess.ExecuteCommand entering
[2019-10-01 15:30:27.261Z] [0001] ExeSessionProcess.ExecuteCommand leaving
[2019-10-01 15:31:27.276Z] [0001] Timeout waiting for WinSCP to respond - asking for callstack
[2019-10-01 15:31:27.277Z] [0001] ExeSessionProcess.RequestCallstack entering
[2019-10-01 15:31:27.294Z] [0001] Exception: System.Threading.WaitHandleCannotBeOpenedException: No handle of the given name exists.
at System.Threading.EventWaitHandle.OpenExisting(String name, EventWaitHandleRights rights)
at WinSCP.ExeSessionProcess.RequestCallstack()
[2019-10-01 15:31:27.294Z] [0001] ExeSessionProcess.RequestCallstack leaving
[2019-10-01 15:31:27.295Z] [0001] Exception: System.NullReferenceException: Object reference not set to an instance of an object.
[2019-10-01 15:31:27.295Z] [0001] Session.Cleanup entering
Re: Winscp assembly getting timeout
Session.Timeout has to be set before Session.Open. Though I do not think it would help anyway.
In what environment are you running your code? What version of WinSCP? Please attach a complete WinSCP .NET assembly debug log file.
kolotan
Hi martin,
i am using
product version : 5.15.0
File version : 5.15.1.9407
attached is the winscp log output.
Thanks in advance.
Description: Winscp log output
Thanks. Though you did not answer "In what environment are you running your code?"
Did you try to play with Windows Scheduler task settings? Particularly with the "Security Options".
