Cannot run script from command line or .bat file
Uyenvu123
Viet Nam
Hi guys
I am very new to scripting and am having difficulty in getting my script to run. I have read through the guides, FAQ and forum postings and there must be something that I am missing. I need to download remote files to a specific local directory and then move the remote files to a different remote directory. The script is below.
option batch on
open StoredSession
cd claim
get *.txt h:\123\ABC\Temp
mv *.txt complete/
close exit
The script is called script.txt and is located in c:\Scripts
I have tried running the script from the command prompts as:
winscp.com /script.txt
AND
winscp.com /%Scripts%"\sctipt.txt"
in each case winscp.com loads and requests the host. Ultimately I want to call this script from a .bat file so that I can automate the daily download.
I appreciate and help and advice you can offer.
Uyen
Re: Cannot run script from command line or .bat file
AND
It should be:
winscp.com /script=script.txt
See
https://winscp.net/eng/docs/guide_automation#script_file
or
https://winscp.net/eng/docs/commandline#scripting
