Mapping Local drives
kishoregowda
Hi, we are using WinSCP 5.9.5V and would like to know how we can configure WinSCP to map local drives of local machine when using WinSCP on a citrix server.
Re: Mapping Local drives
Sorry, I do not understand what you mean by "map local drives of local machine".
You have to map drives in Windows, not in WinSCP.
Or you can open an UNC path/shared folder of your local machine.
You need the latest version of WinSCP to browse UNC paths:
https://winscp.net/tracker/133
kishoregowda
I mean for example, you log in to your workstation and from there you launch a Citrix session to connect to a different network. When you open WinSCP can we see the local drives on the workstation?
Are those real mapped drives? Can you access them from Windows command-line? Can you post a File Explorer screenshot?
