Help
bounce
Australia
Help
Hi All,
im trying to run a batch file and automate it in task scheduler, if i run the batch file on its own it runs fine, as soon as i run it in task scheduler it fails to sendmail like in the batch file.
below is my batch file and script file.
****Batch File****
@echo off
"C:\Program Files (x86)\WinSCP\WinSCP.com" /script=c:\batch\getmyfile.txt
if errorlevel 1 goto error
echo Success
sendmail.exe -t < success_mail.txt
goto end
:error
echo Error!
sendmail.exe -t < error_mail.txt
:end
****Script File****
open ftp://###%40#####.com.au:#############H@######.com.au/
cd /
lcd C:\batch\getmyfile
get -delete getmyfile.txt
# Execute the script using a command like:
# "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\writable\path\to\log\WinSCP.log" /ini=nul /script="C:\path\to\script\script.txt"
Re: Help
Do you positively know that is problem with "sendmail"? Do you get any error message? Do you know if WinSCP succeeded?
bounce
The batch file runs fine when double clicked on and sends email on failure or success on transfer, but when it’s ran in task scheduler it will still download the file but fails to run the error level checking in the batch file!! From reading different posts, in running task scheduler you should run it from as “winscp.exe” and call the script file, but how do you run error level checking running it that way??
bounce
all fixed and got it to work, in task scheduler, under actions i selected the batch file and add the directory to "Start In" option and it worked!!
