Put Files from Azure File Storage to FTP
EMVE-IT
Netherlands
Hi There,
I'm trying to upload some files from the azure file storage to an ftp server with the WINSCP.exe. I've created a function and everything seems to work only the files aren't uploaded.
It seems I'm having trouble to define the correct syntax for the Azure file storage location. Is there more information available to handle such a upload from Azure File Storage to FTP.
Thanks and kind regards,
Marcel
Re: Put Files from Azure File Storage to FTP
I do not know, what does it exactly mean to access Azure File Storage from a "function".
Anyway, WinSCP can work only with local files available using standard Windows paths (local drives, mapped network drives, UNC paths).
If your files are not available this way, you cannot upload when with WinSCP.
