Digest Authentication support for WebDAV
Vishwas
India
Does anyone know if WinScp supports digest authentication for WebDAV access?
If yes, then please let me know the settings.
Regards,
Re: Digest Authentication support for WebDAV
Yes, WinSCP supports Digest authentication.
There are no settings for Digest authentication.
What settings would you need?
Hi Martin,
Thank you for the response.
Is there any settings where I could select authentication type(Basic/Digest/Anonymous) before I request for login?
Regards,
Vishwas
WinSCP always prefers Digest over Basic, if the server supports both.
