Deleting unwanted files when synchronizing
Helvetica
Switzerland
Hi everyone,
I LOVE the synchronize feature of WinSCP, it saves me hours and hours of work when I am uploading to my huge academic website (nearly half a million files).
Sometimes before I upload new files to a section, I need to rename an image, say from RIC_123.jpg to RIC_124 (or I make a new RIC_124.jpg and delete the old RIC_123.jpg from my PC). When WinSCP shows me the list of changed or different files before I confirm the upload, files which are on the server but not on my PC are marked in red and have an "X".
Now my question is, if I tick the boxes of those files on the left, does WinSCP then delete those unwanted files for me at the same time ? Or are they transferred to my PC ?
Re: Deleting unwanted files when synchronizing
Yes.
See https://winscp.net/eng/docs/ui_synchronize_checklist#information_displayed
Though even better is to tell WinSCP that the new and the file are actually the same and the difference can be resolved by a rename (to save the upload):
https://winscp.net/eng/docs/ui_synchronize_checklist#renames
Helvetica
Switzerland
Ah thankyou Martin.
Re the renaming. My website is a huge database of ancient coins. So sometimes when I rename an image/thumbnail/txt file, to correct its reference, I sometimes see if I can find a better example, so the image is not always the same one.
But I'll read the info you cited.
Thanks again.
Yes.
Yes.
The next version will show hints for the icons:
https://winscp.net/tracker/1786
