Unable to remove file using session.RemoveFiles (VB.Net)
kevalsavani
India
I am not able to remove/delete file from local FTP account, below is my code
Dim sessionOptions As New SessionOptions
With sessionOptions
    .Protocol = Protocol.Ftp
    .HostName = "192.168.0.3"
    .UserName = ftp_username
    .Password = ftp_password
End With
Using session As New WinSCP.Session
    session.Open(sessionOptions)
    Dim result = session.RemoveFiles("/app/log.txt")
    For Each x In result.Failures
        Debug.Print(x.ToString())
    Next
    Debug.Print(result.IsSuccess)
End Using
Here is output:
WinSCP.SessionRemoteException: Can't get attributes of file '/app/log.txt'.
Could not retrieve file information
Unknow command
False
If I do
session.RemoveFiles("/app/*.txt")
which deletes all files but I want to delete only single-single file.
Please Help.
Re: Unable to remove file using session.RemoveFiles (VB.Net)
kevalsavani
India
Thanks Martin, I have attached the log file, can you please check and let me know the issue.
Your FTP server is broken. It announces a support for MLSD/MLST commands, while it actually does not support at least the MLST:
< 2019-08-23 20:24:11.258 211-Extensions suported:
< 2019-08-23 20:24:11.258 MLSD
< 2019-08-23 20:24:11.258 211 End.
. 2019-08-23 20:24:11.966 Retrieving file information...
> 2019-08-23 20:24:11.966 MLST /app/log.txt
< 2019-08-23 20:24:12.139 500 Unknow command
You can try to workaround the bug by setting FtpUseMlsd:
sessionOptions.AddRawSettings("FtpUseMlsd", "1")
https://winscp.net/eng/docs/rawsettings#ftpusemlsd
kevalsavani
India
I am getting following error when set this setting
Error
.SessionRemoteException: Lost connection.
Timeout detected. (data connection)
Can't get attributes of file '16f877.pdf'.
Also I have attached the log file.
Can you please look into this and help me out.
Can you login and see a directory contents in WinSCP GUI? Or in any FTP client at all?
Yes I can see, even I can delete files from WinSCP GUI.
Do I have any version issue or it is something else?
Try this:
sessionOptions.AddRawSettings("FtpDeleteFromCwd", "0")
Please post a log file from the script and GUI in any case.
kevalsavani
India
I did tried with options but no luck,
I have attached the file log, from .net and from GUI also.
Please check and let me know what can make this fix, thanks.
kevalsavani
India
Still getting same issue
Can't get attributes of file '74hc04.pdf'.
I have attached the log.
OK, I see. The server does not announce a support for SIZE and MDTM commands.
Anyway, at least the LIST should work. Can you connect to that server and see the directory listing using WinSCP GUI or any other FTP client, running on the same machine as your code?
kevalsavani
Yes, listing and uploading are working fine, quite slow but working fine.
can you please help me out? my client is waiting for this to get a fix so he can start production of devices.
kevalsavani
India
I have downloaded the latest version of WinSCP and tried to remove the file but still getting the same error.
I have attached the log file, can you please check and let me know the solution.
Can you post a log file from WinSCP GUI showing a successful directory listing? Are you running WinSCP GUI on the same machine and in the same environment as your code?
reddypa
same problem
Did this ever get solved? Same problem here, for years now. I delete files from many FTP servers via a script using .RemoveFiles, but I have one client for whom I cannot delete files via a script, yet I can just fine via the UI. Please advise.
Re: same problem
Please start a new thread and post log files both from the code and the GUI.
