SFTP Sync Script Error
Wecks
Weedon
I am using a PowerShell script posted on his site to transfer files from an SFTP site to a local server. Up until recently, it was working but stopped 2 weeks ago and looking at the log I am getting this error message when it runs.
[08/19/2019 12:20:31] Sync Started
[08/19/2019 12:20:31] Error: Exception calling "Open" with "1" argument(s): "Disconnected: No supported authentication methods available (server sent: publickey)
I created a public/private key using putty and I obtained the fingerprint from the win SCP app but I am struggling to get past this. I know the keys have not changed. Does anyone have any ideas?
Re: SFTP Sync Script Error
Can you connect in WinSCP GUI?
If you can, post complete log file both from the GUI and your script.
Solution
the solution to this issue has been found. For you information, if you use the SFTP scrip posted on the WINSCP site you will need to add the lines below in bold.
For some reason when the path to the Key and the passphrase was added it started to work. The parts in bold were added to resolve. (Parts in red are variables specific to your solution)
HostName = "sftp.XXXXXXXX.com"
UserName = "USERNAME"
PrivateKeyPassphrase = "XXXXXXXXXXX"
SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
SshPrivateKeyPath = "C:\Keys\PRIVATEKEY.ppk"
