Automation - download all
bloodclot
Ca
Trying to just download all files from the root (/) of the host to a drive (google - g drive).
I couldn't get it going to download to the local, it came back and said it succeeded but nothing was there?
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "test.test.com"
        UserName = "userabc"
        Password = "passabc"
        SshHostKeyFingerprint = "ssh-rsa 2048 P0rBKJMYf1man8NTYvBftJUs5EdvpSyJGSE/S+SxVy4="
    try
        # Connect
        # Download files
        $transferResult =
            $session.GetFiles("/*", "f:\my drive\sftp", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host "Download of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: Automation - download all
In any case, you are probably missing a backslash in "f:\my drive\sftp\"
See https://winscp.net/eng/docs/library_session_getfiles#localpath
