Cosmetic bug - on Windows 8, shortcut icons are not displayed
ks
Moscow
WinSCP 5.15 does not show icons for shortcuts/folders in Windows 8. After some testing I found out it's more than that - WinSCP actually can randomly display some of the icons, if you enter the same dir once again. Somehow, it selects only some of the shortcuts to display icons for. And if I close WinSCP and relaunch it, it forgets about then and shows no icons again.
Another example: when I launch it and the local dir is C:/Temp, it may show folder icons for about half of the folders that are there. Now if I get out of the dir and then back in, it now displays icons for all of the folders.
And it's all Ok on Windows 7.
Re: Cosmetic bug - on Windows 8, shortcut icons are not displayed
So were it working in earlier versions of WinSCP?
How long does it take to open that folder?
ks
Moscow
Yes, it used to work correctly. I tested older portable versions.
4.3.4, 5.1.8, 5.5.1, 5.7.1, 5.7.2 are just fine.
5.7.3 and higher, 5.9, 5.9.1, 5.11 show some icons, but not all anyway (see the image). This may be related with "Optionally determining local file icon by extension only" from https://winscp.net/eng/docs/history?a=5.7.3
5.14.2 and higher, to 5.15, do not show icons of regular folders (local panel on the left side) when WinSCP starts with that folder open (5.14.1 doesn't have this bug). As the folder is local, it shows it immediately. On the second entry, folder icons are usually displayed, but I saw a case when 1 folder icon was not displayed even then, but when I reentered again, it was displayed finally.
The last bug may be related to "Loading .exe (and similar) file icons asynchronously" from https://winscp.net/eng/docs/history?a=5.14.2
I also tried the hidden configuration option Interface\LocalIconsByExt, it didn't help.
I do not think that any change in 5.7.3 could have caused the difference.
Unless you actually had the Interface\LocalIconsByExt set before.
Did you try to turn it off?
For the 5.14.2 problem, it's more likely related to
https://winscp.net/tracker/1709
ks
I never used Interface\LocalIconsByExt before, only tried it once.
Now I have tested it again, and Interface\LocalIconsByExt=0 helped with folders only (5.14.2 bug).
ks
Moscow
As I wrote in the email, the debug version didn't fix the 5.3.7 problem, but it fixed the 5.14.2 one.
As for 1709, I had no crashed, and anyway, I don't see what use is in the fact that the problem is related to another problem.
ks
Moscow
Well, I tested all versions of WinSCP one by one (portable, of course) and found exactly the border where the bug shows up. Also, I found an item in the changes history that is related to icons at least. Can't be a coincidence, right?
