I can´t connect with private key without password
Nacho
Zaragoza
I trying to connect SFTP with .ppk file without password with .NET assembly with session options C#, this is my code
SessionOptions sessionOptions = new SessionOptions();
sessionOptions.Protocol = Protocol.Sftp;
sessionOptions.HostName = "xxx.xxx.xxx.xxx";
sessionOptions.PortNumber = 22;
sessionOptions.UserName = "user";
sessionOptions.SshPrivateKeyPath = path
   try
       session.Open(sessionOptions);
   catch (Exception ex)
       MessageBox.Show(ex.Message);
The message I receive when trying is:
SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.SshHostKeyFingerprint is not set
I try to connect with the graphical interface with the same configuration and it works at the first.
Some suggestion?
Thanks!!!!
Re: I can´t connect with private key without password
Well, so do what the message says:
Set the SessionOptions.SshHostKeyFingerprint.
https://winscp.net/eng/docs/library_sessionoptions#sshhostkeyfingerprint
If you can login in GUI, it can generate a working code template for you:
https://winscp.net/eng/docs/ui_generateurl#code
Nacho
Thank you! I scan fingerprint and add to SessionOptions.SshHostKeyFingerprint and it works perfectly. Now I need a dll that works fine with 32 bit.
Nacho wrote:
Now I need a dll that works find with 32 bit
WinSCP .NET assembly works both in 32 and 64-bit.
