Synchronize files and folders existing in both remote and local directories only
kjc
I am trying to synchronize a remote and a local directory, only updating files and folders existing in both remote and local using the .NET/C# library.
In the documentation it says:
"Files in the source directory not present in the target directory are by default transferred as well (disable this using the option Existing files only)".
I am not able to find the option Existing files only.
How is this done in code? Do you need to use the session.CompareDirectories method and loop through each ComparisonDifference and do a deletion for each of them, or are there better alternatives?
