File recognised as directory when trying to upload
ddnnkubi
germany
A customer of mine is currently facing a problem while uploading a file.
We are using version 5.15 of WinSCP. The used protocol is unencrypted FTP. The user is trying to upload a local .csv file to a remote server via dragg and drop. The upload is being interrupted by the Error code 267, The diretory name is invalid. It seems like, WinSCP thinks that the .csv file is a directory and tries to list all files in this directory. You can also see the error message in the attached picutre.
Thanks in advance for you help!
Dennis
jesse.rodriguez@...
Source Files seen as directories.
I am having the same issue with The upload is being interrupted by the Error code 267.
chuyrod
Error listing directory - Code 267
Using WinSCP 5.19.2 I am trying to upload a directory with several files. I am receiving the message Error listing directory. Empty directories are created instead of the files.
  • winscp.log (301.74 KB, Private file)
Re: Error listing directory - Code 267
@chuyrod: WinSCP sees the BCP GamePlan 2018.xlsx as a folder, is it? Or is it a file? How does it look like in WinSCP file panel? What do you get, if you do dir U:\My Documents\BCP in Windows command-line? What is the U:? A network drive? Hosted where? Isn't it Samba or something like that?
chuyrod
Howdy, thanks for the quick reply. See my answers below.
U: Drive is mapped to a UNC Path on Windows Server in my AD Profile as my home drive. In WinSCP the the file is recognize as a file Microsoft Excel Worksheet. For a successful command dir from the prompt, I enter the following --> dir u:"My Documents"\BCP
It doesn't matter the file type. It seems to be related to mapped UNCs paths. Looking forward to your reply as this has come up several time before.
chuyrod
Hello, steps performed:
  1. Open WinSCP
  2. Connected to SFTP Site
  3. Source: Browsed to U: folder path mapped to \\server\share
  4. Destination: Browsed to sftp folder path
  5. Highlighted files from source location
That is when empty directories or created instead of the filenames. See attached trace file.
Thank you,
  • WinSCP24C4trace.zip (522.49 KB, Private file)
chuyrod
Hello, here is a new log file using the latest build sent to me. Thank you very much.
Jesse
  • WinSCP3A54trace.zip (1.12 MB, Private file)
Solution?
Hi, I have a customer that have the same issue. WinSCP thinks all files is directories. He is using the latest version of the program. Is there any fix available?
Re: Solution?
When trying to upload any file from example \\hostname\c$ WinSCP seems to believe that it's a directory. I have tried with several different file types but we have the same issue with all of them. The version that is being used is 5.19.2
Re: Solution?
@Guest: Please attach a full session log file showing the problem (using the latest version of WinSCP).
Re: Solution?
@martin: Full paths is removed as you might see from the log but the information that matters should be there. As you can see during the upload process WinSCP belives that the .xlsx file is a directory instead of a file.
  • upload error.log (5.37 KB, Private file)
Re: Solution?
@Guest: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
