The script works well when run in PowerShell ISE but does not work through Task Scheduler
sachinG
India
Hi, The below script does upload a file to remote server successfully when ran in PowerShell ISE manually but shows below log in the session log and does not upload any files when executed through Scheduler. Any suggestion are greatly appreciated.
> 2019-07-14 21:49:30.655 Script: put -nopermissions -nopreservetime -transfer="binary" -filemask="|*/" -- "\\servername\directoryname\*" "/remotepath/"
< 2019-07-14 21:49:45.658 Script: No file matching '*' found. (System Error. Code: 1317.
< 2019-07-14 21:49:45.658 The specified account does not exist)
The Script as below:
param (
    $localPath = "\\LocalUNCPath\*",
    $remotePath = "/remotepath/",
    $backupPath = "\\LocalUNCbackupPath"
try
    # Load WinSCP .NET assembly
    # Setup session options
        HostName = "hostname"
        UserName = "userid"
        Password = "password"
        SshHostKeyFingerprint = "ssh-rsa key"
    $DateTime = Get-Date -format dd-MM-yyyy
    $session.SessionLogPath = "C:\LogDir\Sessionlog$DateTime.log"
    try
        # Connect
        $transferOptions.FileMask = "|*/"
        $transferOptions.FilePermissions = $Null
        $transferOptions.PreserveTimestamp = $false;
        # Upload files, collect results
        $transferResult = $session.PutFiles($localPath, $remotePath, $false, $transferOptions)
        # Iterate over every transfer
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup"
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupPath
                Send-MailMessage -To “<EmailID>" -From “<EmailID>" -SMTPServer smtpServerName -Subject “Upload of $($transfer.FileName) Successful - $env:COMPUTERNAME” -Body “Upload of $($transfer.FileName) Successful: $env:COMPUTERNAME”
            else
                Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
                Send-MailMessage -To “<EmailID>" -From “<EmailID>" -SMTPServer smtpServerName -Subject “Upload of $($transfer.FileName) failed - $env:COMPUTERNAME” -Body “Upload of $($transfer.FileName) failed: $env:COMPUTERNAME $($transfer.Error.Message)”
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: The Script works well when run in Powershell ISE but does not work through task scheduler
Most probably the local account, used to run the Scheduler's task, does not have permissions to the shared folder \\servername\directoryname.
See also My script works fine when executed manually, but fails or hangs when run by Windows Scheduler, SSIS or other automation service. What am I doing wrong?
Thanks for the reply @Martin. I had specified the same account to run this task from the Task Scheduler's which I am using to run it from PowerShell ISE. Also tried to create the files manually in the UNC path using the same account which is successful.
So can do dir \\servername\directoryname in your PowerShell script, before you do $session.PutFiles?
Also, please attach a full session log file showing the problem (using the latest version of WinSCP).
sachinG
India
Thank you Martin, Doing below two things in a Windows scheduler for this particular batch, fixed this issue for me.
1. Unchecked "Run with Highest Privileges"
2. Select option "Run only when user is logged on"
Best Regards,
Sachin.
hajareyogesh1979@gmail.com
india
same issue Script working fine while running from powershell ISE but not working in Task Shedular
Same issue for me, script working fine while running from PowerShell ISE but not working in Task Scheduler.
india
While running the Script in Windows Powershell ISE it is working fine. Task Scheduler does not work
getting a success below result in Powershell ISE
PS D:\YH SFTP\TEST_Staging> D:\YH SFTP\TEST_Staging\1_To_Staging_Final_22_OCT_2020_Ver_2.ps1
Upload of D:\TEST_STAGING\Staging_Send_TO_\3_22_OCT_2020.txt succeeded, moving to backup
but when I schedule the same script in at all.
-Command  "start-process -verb runAs "powershell " -argumentlist "D:\YH SFTP\TEST_Staging\1_To_Staging_Final_22_OCT_2020_Ver_2.ps1"
