synchronizing script stops work - I was using it for ages
miloskrizan
Slovakia
Hello Martin,
I was using this synchronizing script for ages and it worked fine. It should synchronize files, folder, subfolders of local directory to remote(server) with mirror - so copy those existing files that are with newest timestamps AND ALSO copy all files/folders that are not on remote.
option batch off
open sftp://user:pwd@url -rawsettings SendBuf=0 SSHsimple=0 PingType=1 PingIntervalSecs=10 Compression=1 -timeout=10 -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
option transfer binary
option exclude "[~]*"
synchronize remote -mirror "d:\B I Z N I S\ine" "/cecho/Cloud"
Close
Last days I found out that some of my folders were not synchronized (I am not 100% sure if I ran the remote windows server Update or I updated the Bitvise SSH server - probably yes) But from this moment the synchronizing script mentioned above stops to work. It says: Nothing to synchronize even if there are new folders and files.
I review almost all the forums with synchronizing and I can see that a lot of errors that people made is (from log file) there stayed "ExistingOnly mode" in their log files - that means the script was not correctly coded. But as I said I have never changed my code and it was working. And now I tested it and every time in my log file I can see existing only mode.
Is there any default settings for synchronization? Or what switch exactly I should use to synch also new files/folders?
Thank you
Re: synchronizing script stops work - I was using it for ages
Indeed, the problem is the "existing only" mode.
Your script is not isolated from GUI configuration. It's likely that you have changed your GUI configuration, what broke the script. Try adding /ini=nul switch to WinSCP command-line.
See https://winscp.net/eng/docs/scripting#configuration
This is not what the -mirror mode does. The mirror mode copies all files that have different timestamps. Not only newer, but also older. If you want only newer (and new) files, remove the -mirror switch.
miloskrizan
Slovakia
Works like a charm! I read the same in the previous posts but I was not sure that this can solve my issue. I tried it earlier but I made some changes on SSH server side, so something was wrong. But anyway I learned that If I do not want to use /ini=nul I can reset the winscp gui into default settings. It is places in Tools/CleanUp https://winscp.net/eng/docs/ui_cleanup
With reseting the settings I did not need to use the meantioned switch.
Thank you Martin. You rock!
But then you are prone to the same problem sooner or later. The /ini=nul is a better solution.
