Upload same files to multiple FTP directories
drudkin
I have a couple hundred files (local) that i need to upload to 63 different folders (FTP Server). Can i do this with one command or do i have to do each folder individually
Re: Upload same files to multiple FTP directories
You have to use one command per directory.
But it's not that more complicated.
If you are uploading all files from the current working directory, you just prefix each folder with put *:
put * <folder1>
put * <folder2>
drudkin
Thank you for the information, unfortunately i have no idea how to do that. I can place the commands in a text file, that is easy, but I have no idea how to run that script. Very new to SQL and automation like this. Any help you could give would be appreciated
put * <folder1>
put * <folder2>
Start here:
https://winscp.net/eng/docs/guide_automation
drudkin
Martin,
Thanks for pointing me in the right direction. I used the automated function to create the script file for me and then saved it as a text file, example of script below.
The only problem now is that i have no idea how to actually execute the script. I have read everything and I am sure that it is just something i am not understanding.
Your help is appreciated in advance
open sftp://drudkin:xxxxxxx@xxxxx.xxxxx.com/ -hostkey="ssh-rsa 1024 RO0ArzoIscQoMNpHvoyhKy/8EoRg+8GbkE4uKbBVooQ="
lcd C:\Users\drudkin\Documents\Zoom
cd /
put * <Advanced Air>
put * <Machine Specialties>
put * <Frey & Weiss>
put * <Alro Machine and Tool>
put * <Aerometals>
put * <Precision Mold and Tool>
put * <Forster Tool>
put * <Owens Industries>
put * <BLUSA>
put * <Alta Precision>
put * <International Precision>
put * <AAR LGS>
put * <Mayday Manufacturing>
put * <CM Manufacturing>
put * <Aero-Glen>
put * <Skyspares>
put * <Cummins Aerospace>
