Show path to WinSCP.ini in the title bar
Sopor
Sopor avatar
Sweden
It would have been nice if it was possible to see what WinSCP.ini i use. So an option that make the path visible in the main window would have been nice (if the user is not using WinSCP.ini it could only show: Registry). Either show it in the title bar or in the status bar.
You already have "Path in window title" so why not add more options to it :)
Sopor
Sopor avatar
I believe it will not be many +1 because the hidden statistics are very high. I don't even know how to "ask for this" as you write: "We will see, if more people ask for this".
No other suggestion have been voted for :(
If someone posts a similar separate post/suggestion.
