Downloading only new files on server
Omega42
Ireland
Apologies if this has been asked and answered before, I did have a look through the fourm but couldn't see anything.
I'm looking to set up a script that logs on to a server every hour to check for new files and downloads them.
I don't think I can use sync as files will be moved on my local machine so I would end up re downloading the moved files.
Like wise the <1h would not work as the local PC may be switched off.
I'm thinking a external file on local PC with timestamp of last download then when it's next run.
Thanks in advance
fairudyn
Singapore
Re: Downloading only new files on server
Thanks in advance
Hi you can use
put -neweronly
That would indeed be the only solution, given your constraints. But WinSCP does not support it out of the box.
It should not be difficult to script this in PowerShell using WinSCP .NET assembly.
I'll try to write an example script in few days.
Vann_the_Red
Piggybacking
Martin,
That script using file history is brilliant and almost solves my problem as well. I worry, though, that the list will become unwieldy quickly. I need to script several high traffic downloads. It seems like the simplest path would be to save the time stamp of the most recent file, get a directory listing, sort by recency, and download those added since the last download. Does anyone see a simpler solution? Are there pointers to doing it that way?
TIA,
VtR
Re: Piggybacking
If you can rely on the timestamps, than it's indeed a way to go.
For an example of downloading files newer than a given timestamp, see for example:
https://stackoverflow.com/q/37007929/850848#37010471
