Console crashes when started from .Net
Arne
I'm trying to use WinSCP, runtime, from a program I'm working on. I've already got PLink up and running and I'm going to use that for issuing commands. I'd like to use the WinSCP sychronize function for file transfer though :)
I was able to redirect the WinSCP output stream (.Net), but the WinSCP3.com crashes when I start the process (even if I don't redirect the stream). If I just remove the .exe, I get the output stream nice and tidy as it complains it can't find the file.
I looked up the error code, and it complained about some memory conflict (I think).
I also looked at a working .com file (started fom cmd) and compared it to a crashed one (started as a process in .Net), but the only difference seemed to be that the envornment keys (not values) in the latter one were all lowercase. The .com file also crashes After it has started the WinSCP.exe process (Problem communicating with WinSCP.exe?), which seems to be working fine... It lives on as a seperate process after the WinSCP.com is terminated.
Got a clue about this? :)
Arne
Re: Console crashes when started from .Net
What do you mean that you looked at a working .com file?
I've started it from cmd (command prompt). Works fine then. I'm just not able to start the process from .Net. crashes with *testing*
Eception code 0xc0000005 first then again
Eception code 0xc0000005 and then
Eception code 0xc0000027.
Don't know what the exception codes stand for... Or if they're relevant at all
Can you show me piece of code you use to run WinSCP? I do not have a .NET environment, however I can try to implement something similar in C.
Arne
I've been writing this in VB.Net :oops: (Not my choice):
Dim objStarupInfo As System.Diagnostics.ProcessStartInfo
objStarupInfo = New System.Diagnostics.ProcessStartInfo(System.Windows.Forms.Application.StartupPath & "WinSCP3\WinSCP3.com")
'Setting startup parameters
'Redirecting input and output streams
objStarupInfo.CreateNoWindow = True
objStarupInfo.RedirectStandardInput = True
objStarupInfo.RedirectStandardOutput = True
objStarupInfo.RedirectStandardError = True
objStarupInfo.UseShellExecute = False
objStarupInfo.WorkingDirectory = System.Windows.Forms.Application.StartupPath & "\WinSCP3"
Me.m_objSCPConsole = New Process(objStarupInfo)
Me.m_objSCPConsole.Start()
