download and delete question
xodiacx
ph
Hi all,
I have some question regarding the download and delete function of winscp, I'm currently using version 5.15. my question is when I interrupt the process is my files are safe from the remote server? will it still continue the process? because there is this case right now that I'd interrupted a download and delete of 3.3GB worth of important files now when I came back to check again the folder is empty. the system confirm that I've successfully interrupted it.
THanks
Re: download and delete question
If you are asking, if WinSCP deletes the files, if you interrupt a "download and delete" operation during the download phase -- then no, it won't delete the files.
If you have doubts, please attach a full session log file showing the problem (using the latest version of WinSCP).
