hemantkumar.suppamani@celcom.com.my
Hemant2305
Hi Team,
we have been trying to perform automation but for some reason the file is not being moved to the remote server. appreciate if you can advise on this.
i followed this link: https://winscp.net/eng/docs/guide_schedule to do the automation.
Appreciate if you can help on this,
Thank you
Description: attached is the screesnhot from task scheduler and logs with script used for the automation
Re: hemantkumar.suppamani@celcom.com.my
Your command line is wrong. It should be (one line):
/log=c:\GLLogs\winscp.log /command "open sftp://12716:Temp%401234@10.5.144.41/ -hostkey=""ssh-rsa 2048 u85/zQW1QOs+SpCxQCvmA5Z9WNyYYUTB1mSHStjoTCg=""" "synchronize remote C:\FTPdata\matrixx\PROD\GLposting\* /home/vs12716/GLPosting" "exit"
https://winscp.net/eng/docs/guide_automation
https://winscp.net/eng/docs/commandline#scripting
https://winscp.net/eng/docs/commandline#syntax
