Extremely annoying behavior with SSH recycle bin
redneonglow
I've used WinSCP for a long time, but the SSH recycle bin does something completely annoying. I don't know if this is a bug or a feature, but I'd love to see it removed.
If you have an SSH recycle bin and enable the "overwrite to recycle bin" option, and you are overwriting files to a partition which is not the same partition as the recycle bin directory is on (such as an external drive on /mnt/something or /media/something), an infinite loop of weird errors are given with the option to Abort, Skip, Retry, etc. Only "Abort" works, and then you have to go into settings and disable the "Overwrite to recycle bin" and start over.
I've had this issue on every SFTP connection I use, including on both LAN and Internet transfers.
Again, I'm not sure if this is a bug or a feature, but it is extremely annoying, and should be fixed IMO.
Thank you, Red
Re: Extremely annoying behavior with SSH recycle bin
redneonglow
I made a mistake in the original message, this is not an external drive, it is a non-LVM LUKS encrypted drive with partition type ext4 and mounted to /mnt/(REMOVED).
Here is the relevant part of the log file, uploaded to the forum in private mode. "Retry" is selected twice, followed by "Abort." The mount point of the drive has been replaced with (REMOVED) and the username replaced with (USER).
  • winscp-overwriteprob-censored.txt (6.46 KB, Private file)
Description: Here is the relevant part of the log file, uploaded to the forum in private mode.
redneonglow
OK, but you should press Skip, not Retry or Abort. What behaviour do you get with Skip?
After "Skip" I get "Cannot overwrite remote file, Press "Delete" to delete the file and create new one instead of overwriting it." Again with the same Error 4 listed.
Pressing "Delete" does nothing and gives me the same message from before. Skip, Delete, Skip, Delete...
redneonglow
Actually it moves on to the next file if I press "Skip" twice.
Here is the relevant part of the log, uploaded privately, with the personal information removed as mentioned above.
  • winscp-recyclebin-skip-censored.log (17.62 KB, Private file)
redneonglow wrote:
I still have the same problem with the development version.
Can you please respond to my email and send me a new session log file?
redneonglow
Here is a log file of the new development version, with the same things "(REMOVED)" involving the transfer and attempt to overwrite files. In each of the three files, I do "retry" twice followed by "skip" once.
  • bunker-developmentver-20190716.log (28.15 KB, Private file)
I'm not sure I understand, what problem do you see now.
The file could not be moved to the recycle bin. You got a message about that. You retried the move twice, what could not help. Then you skipped the move and the file was successfully overwritten and uploaded. That's the expected behavior. What did you expect differently?
redneonglow
Why would an error message where you have to click "skip" move the file? To my knowledge "skip" would skip that file and attempt to move the next one. The file was overwritten after clicking "skip"? That's not good.
Again in all other cases, I have no error message when attempting to overwrite files. But I'd imagine it would be universal that "skip" on an error message would skip the operation.
The message is to inform you that the overwritten version of the file will be lost (in case you expected it to be moved to the recycle bin).
The "Skip" here means that the "move to recycle bin" operation will be skipped. The message does not say anything about an upload/overwrite.
redneonglow
Oh OK.
Why won't it move the file to the recycle bin though? That's what I want it to do.
Because you cannot move files between partitions.
WinSCP would have to download the file and upload it back to the other partition, what you probably won't like (if WinSCP even had a way to find out that the file is on different partition than the recycle bin, what it does not).
redneonglow
From the eyes of WinSCP, what's the difference between copying a file from /home/user/Documents to /home/user/recyclebin and copying a file from /run/media/user/jumpdrive to /home/user/recyclebin?
First, this is about moving, not copying. Those are two very distinct operations (and even more so, in the context of this question).
There's no difference in the "eyes of WinSCP". But that's irrelevant. It's the server that does the move. And in the "eyes of a server", you cannot move a file to another file system (as the very existence of this topic proves).
redneonglow
And this "server move" which WinSCP uses is something different than the normal mv command?
The common *nix mv command moves the files, when they are on the same file system. This is the same operation that SFTP server "move" functionality does.
But then they are not, it does not (cannot) move the files. It copies the files and then deletes the original. Most SFTP servers do not support "copy" operation.
See https://winscp.net/eng/docs/protocols (section "Direct File duplication").
