GetFiles() transfers empty File
Chaos
Hi Guys,
I'm starting with the WINSCP Lib and it looks quite good.
Now I'm using the WinSCP Client to compare what I am doing.
I have a simple text file on an sftp with a few lines of content; when I transfer it, it arrives beeing an empty file.
Here is the code I use:
 using (var session = Connect())
                if(!session.FileExists(fileName))
                    throw new FileNotFoundException(fileName);
                var tmp = Path.GetTempFileName();
                var result = session.GetFiles(fileName, tmp);
                if(!result.IsSuccess)
                    throw new AggregateException(result.Failures);
                return tmp;
found it, its evil!
Session.FileExists will return true for a relative path
Session.GetFiles will just create an empty file
[/b]
Re: GetFiles() transfers empty File
Chaos wrote:
found it, its evil!
[/b]
