Bug affecting V5.15.2
Clicking (single-click)/highlighting a folder or even searching with a query returning a folder as search result (in login/host select list view) directly triggers to initiate the connection (without pressing enter or OK) - only affecting Version V5.15.2 - downgrading to V5.15.1 solved this...
Re: Bug affecting V5.15.2
Do you mean that if you single-click on a site folder on Login dialog, WinSCP starts connecting straight away? I cannot reproduce this.
Re: Bug affecting V5.15.2 up to 5.15.5
Hi martin,
I probably figured out some detail when the problem will occur:
- Use a master password
- Create a folder in login view
- Create connection entries (i.e. 5) inside this folder.
- add a stored password for some (i.e. 2) of the accounts - protected by the master password
Now, by just single-clicking (or searching) the folder containing accounts with stored passwords WinSCP does now ask for the master-password, even if no account really connects.
Even with a click on cancel the master-password query is repeated in the number of accounts with stored passwords.
Expected behavior:
Master password queried only if protected account is dbl-clicked/connecting or edited...
Thanks! I have fixed that:
https://winscp.net/tracker/1799
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
I have sent an e-mail!
WinSCP 5.16.1 beta with the fix has been released meanwhile already.
I appreciate any feedback.
