delete remote files in special situations
Gwynbleidd
hey guys,
im totally stuck on this :(
i have a script which:
1) connect to remote supplier.
2) synchronize remote files and sub folders from this supplier to my local windows folder.
after i sync all files, i have a system that take the files from the local windows folder and delete them.
this cause the following issue, the script run every few seconds and notice that the local folder is empty and re-synchronize.
thus i get the same file over and over again.
is there a way to delete remote files after sync?
i swear i couldnt find a solution for this, only a powershell script which i couldnt get to work.
please help :(
Re: delete remote files in special situations
OK, so you did find a solution for this.
So maybe you should ask a question about your problem with the script you have found.
Gwynbleidd
im not an expert in powershell so i couldnt get it to work + i rather use the script method.
in the end i used put + get for each sub folder and exclude the folders in the root :(
