Could not load WinSCP .NET assembly
I'm trying to automate file transfer with powershell. I downloaded .NET assembly and write the code in powershell. I encountered a problem when I tried to load WinSCP .NET assembly.This the code to load WinSCP .NET assembly.
And this is the error that I received
Add-Type -Path "C:\Users\TEST\Documents\WinSCP-5.15.2-Automation\WinSCPnet.dll"
Add-Type: Unable to load the file or assembly 'file://C:\Users\TEST\Documents\WinSCP-5.15.2-Automation\WinSCPnet.dll' or one of its dependencies. This assembly has been co built by a runtime newer than the runtime currently loaded and cannot be loaded. Level C:\Users\TEST\Desktop\SynchroFile.ps1: 3 Character: 9 + Add-Type -Path "C:\Users\TEST\Documents\WinSCP-5.15.2-Automation\WinSCPnet.dll" + CategoryInfo : NotSpecified: (:) [Add-Type], BadImageFormatException + FullyQualifiedErrorId: System.BadImageFormatException,Microsoft.PowerShell.commands.AddTypeCommand Error: Cannot find the type [WinSCP.Protocol]: check that the assembly in which it is located is loaded.
