move remote files with different extension
cipo80
Vicenza, Itay
Hi All, I've build this simple script to get only .pdf from a remote SFTP, then move the pdf's and .xml to the remote directory "scaricati".
I've try with mv *.* /out/scaricati/*.* but isn't working, I've try splitting the two mv command and it's working.
Isn't important, but is it possible to move all files extension with one command?
Thanks in advance
open sftp://xxx:xxx@xxx:8022/ -hostkey="xxxxxxx="
cd /out
lcd "E:\report"
get *.pdf -filemask=/scaricati/
mv *.pdf /out/scaricati/*.pdf
mv *.xml /out/scaricati/*.xml
Re: move remote files with different extension
The mv *.* /out/scaricati/*.* should work in general.
The problem is probably the scaricati subfolder, as the the *.* matches even the subfolders. So the command is trying to move /out/scaricati to /out/scaricati/scaricati, what is obviously not possible. In such scenario, your solution is the best you can do.
cipo80
Vicenza, Itay
Re: move remote files with different extension to a folder and create it if not exist.
Thank you Martin for the reply, I've another doubt, I'm not sure if the remote service delete the "scaricati" folder or not and I need it before moving files.
After some google-searches I've found an old post with the same scenario and I've added four commands rows before files moving.
I've understand the option batch continue if the directory already exist, and the mkdir, but I don't understand the last two commands option batch abort and stat foldername.
cd /out
lcd "E:\report"
mkdir scaricati
option batch abort
stat scaricati
Thanks in advance and have a great w.end!
With option batch continue the mkdir would succeed, even if it failed to create a (non-existent) directory. stat foldername (in abort mode) fails, if the folder/file does not exist. So it's a way to abort the script, if it failed to create the folder.
See also https://winscp.net/eng/docs/script_checking_file_existence#scripting
