List root folder.
HugoMendes
List root folder.
SessionOptions sessionOptions1 = new SessionOptions
Protocol = Protocol.Ftp,
HostName = "webserver",
UserName = "webguest",
Password = "1",
// Connect
session.Open(sessionOptions1);
//List files
string remotePath = ""; <---Problem here
RemoteDirectoryInfo directoryInfo = session.ListDirectory(remotePath);
//See last file
directoryInfo.Files.OrderBy(p => p.LastWriteTime).ToArray();
string strfilename = directoryInfo.Files.First().FullName;
//Copiar o ultimo
status.Text = strfilename;
string exePath = Application.StartupPath;
exePath = exePath + "\\MyFiles\\";
tempPath = exePath + "img_1.bmp";
session.GetFiles(strfilename, tempPath,false);
If I want to enter the root folder of the ftp server what should I write in remotePath?
Also, i used directoryInfo.Files.OrderBy to order by time, is there a way to filter the files like only retrieve the *.bmp files?
Re: List root folder.
Login with GUI, browse to the "root" folder and check what path do you see in WinSCP panel. It would typically be /.
There's Enumerable.Where extension method:
https://learn.microsoft.com/en-us/dotnet/api/system.linq.enumerable.where
Or you can use Session.EnumerateRemoteFiles instead of Session.ListDirectory. It supports filtering file by file mask.
https://winscp.net/eng/docs/library_session_enumerateremotefiles
Both approaches are covered in my answer to:
https://stackoverflow.com/q/34680848/850848
Also see
https://winscp.net/eng/docs/library_example_listing_files_matching_wildcard
