Connected in GUI but cannot connect using script in batch file when using private key.
graga
Australia
I connected successfully in winSCP GUI.
From the session I generated Session URL/Code that I saved as .bat file.
Here is the script:
@echo off
/log="C:\temp\WinSCP.log" /ini=nul ^
/command ^
"open sftp://myname@ftp.hostserver.com/ -hostkey=""ssh-dss 1024 OlabPXrXjhEHLUGj0Mh2AgwokSZhory81gKZTd/tQ/c="" -privatekey=""C:\FTP\test.ppk"" -passphrase=""MySecretKey"" -rawsettings ProxyPort=1" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
And here are the log lines:
From GUI:
. Server offered these authentication methods: password,publickey
. Prompt (password, "SSH password", <no instructions>, "&Password: ")
. Using stored password.
. Sent password
From Batch:
. Disconnected: Unable to authenticate
Here I'm stuck.
Re: Connected in GUI but cannot connect using script in batch file when using private key.
Please attach complete log files both from GUI and script.
graga
Australia
I found the problem / solution.
When you save session into script, winSCP does not save the password.
The "open" commend in generated script was:
but should be:
"open sftp://myname:mypassword@ftp.hostserver.com/ -hostkey=""ssh-dss 1024
All is working now.
It does. As long as you have the password saved into the your site.
I didn't expect you need a password, as you have a private key specified in your script.
